Home Crown Forum Crown Amplifiers
Crown i-tech 4x3500hd different temperatures
Hello.
I have an amplifier Crown i-tech 4x3500hd.
And channel 3 is always warmer then the others. It has plus 2-3 degrees Celsius. Is it issue? Thank you
  • HARMAN_RobHARMAN_Rob Sr. Manager, Professional Services Group
    Doesn't sound like an issue, esp because you say it's working correctly. It may be a relevant piece of info if the amp had some other issue but a 2-3-C° difference between channels shouldn't be a concern.
    Is there adequate ventilation around it, is it in a rack with other gear, and/or are any air inlet/outlet passages blocked?
  • edited March 2019
    Amplifier is in rack. Thire is a disstance from all sides. But why has amplifier this difference of temperatures between channels?
    I couldn't say without more info.
    Is this the same amp that you changed the fan (or fans) on? Maybe a different fan speed or different CFM spec could affect temperatures across the channels.
    If you're still concerned, I'd recommend a quick call to HARMAN Pro Tech Support.
