XLS-1502 Aux. Connection
Can anyone provide me with a part number for a 3-pin connector (female) that is compatible with the Aux. connection on the rear panel of my XLS-1502? A Mouser.com or DigiKey.com part number would be appreciated. Thanks!
Best Answer
HARMAN_Rob Sr. Manager, Professional Services Group
Sure, that's a 3-pin phoenix connector. https://www.google.com/search?q=3+pin+phoenix
Answers
Cool! Thanks a lot!
One thing to keep in mind... there are smaller phoenix connectors and there are larger ones, if you're going to order them online. The one on the amp is the larger one.
FWIW... I found the Phoenix Contact plugs I needed at Parts-Express.com They were part #091-371 They cost $1.49 for a 4 pack.
I assume you are going to use it to trigger the amp remotely?
if so, before you bother read: https://proforums.harman.com/crown/discussion/125320/crown-xls-1502-remote-trigger-two-big-issues#latest
Yeah I saw that earlier. I have other things on order at the moment so I haven't gotten around to actually hooking up a relay to control sleep mode yet.
