Invert phase with Soundweb Designer
Hello!
I want to drive a 4 Way PA - System with a Soundweb 9088 running Firmware V 1.66
Everything's self explaining so far, except of one thing:
I need to turn the phase on two outputs 180 degree. In the soundweb designer I found the device \"Filter-Phase\". As i understand this tool shifts the phase relating to the preselected frequency - so its not the right tool for me.
In the \"4 Way Crossover\" device I use in my program the \"Delay/Phase\" window is blank.
I would welcome any recommendations how to invert phase in the software.
In the worst case I'll exchange wiring at the amplifier output terminals.
Thanks and best regards -
George
PS: Please excuse my bad english.
George
The Gain object also has a phase button.
FYI - these details are included in the Help. If you are using Windows 7, 8 or 8.1 then you need to download the Microsoft update below so that Windows can open the Help.
https://www.microsoft.com/en-us/search/result.aspx?q=WinHlp32.exe&form=dlc
Soundweb Designer will not work in Windows 10.
If you require assistance then please contact tech support as it may take weeks for other users to answer your question on this forum. This forum is not a conduit to BSS technical support.
found the polarity feature in the gain device 5 minutes ago :oops:
anyway - the 9088 is maybe outdated, but i've a lot of fun progaming this thing. it was worth recapping.
regards,
george
