How to swap out a replacement 9088ii in a design
For the life of me I could not figure this out or find a post about this. Maybe this has been covered but here is my workaround.
In the network window go online and find your new device that is not in the Design (should show up in the \"Devices on Network\"). Rename that new device to what ever name you desire. once the name is changed go offline.
Open the design window.
Go into Design mode (Alt+D).
Right click on the device that you are replacing.
go to Properties.
Change the name in the first window to the name you chose earlier.
Go to Options and make sure the configuration matches the replacement device
Once finished hit okay
The name above the device should now have changed to what you just created
Open the Network window and go online.
Here you should be prompted that the new device needs loading.
Load up the new device and everything should be ready to go!
Best of Luck!
Robert
Audio Engineer
Harvest Christian Fellowship
Riverside, California
go to Properties.
Best of Luck!
Robert
Audio Engineer
