Home BSS Forum BSS Forum Archive Discussion Soundweb London/Contrio wall controllers and iOS Motion Control
Contrio Wall Controllers Gateway
Hello,
I use the Audio Architect 1.95.3. Is it possible there at the Contrio Wall Controllers no gateway entered? There will always be automatically entered a gateway. If you want to register with the Gatway 0.0.0.0 he will not accept this. In an earlier version of Audio Architect that was.
Thanks in advance.
poe
  • Hello,
    no any idea about this ?
  • \poe\ wrote:
    Hello,
    I have observered the same problem, but it hasen't affected the performance in any way.
  • I have observered the same problem, but it hasen't affected the performance in any way.
    Yes, it is clear that the performance is not affected.
    It comes to routing me. Our BSS equipment running in a corporate network and there is ie IP x.x.x.1 the gateway of the instruments from other networks are connected Connects and other networks reachable. This is not desirable and so also was the gateway IP 0.0.0.0. This is no longer possible with the new firmware.
    Therefore, the question whether there is another way.
