Blu-50 and POE+ Switch
Hello,
I have a problem with a Blu-50 and a Cisco Catalyst Switch. The switch supports POE + and the Blu-50 also starts but, I can not connect. Ips and Hqnet addresses are set correctly.
When I all operate with the power supply and only the power producing and then plug in the network cable it works.
I then times to test the POE + switch on but off, then look wildly Locate LED.
I put then starts the power supply back on and the Blu-50 again I get no connection only if, I separate the Blu-50 from the network and power supply, and then, the power adapter and then the network cable insert I get a connection.
The switch is new and there is the problem in other ports
What could that be? Can I switch off the + fully POE on the Blu-50 anyway?
Hope it is understandable .....
Thanks in advance.
Thanks in advance.
Is aware of the problem? Is there a solution?
From wikipedia:
The original IEEE 802.3af-2003 PoE standard provides up to 15.4 W of DC power (minimum 44 V DC and 350 mA) on each port. Only 12.95 W is assured to be available at the powered device as some power dissipates in the cable.
The updated IEEE 802.3at-2009 PoE standard also known as PoE+ or PoE plus, provides up to 25.5 W of power. The 2009 standard prohibits a powered device from using all four pairs for power.
This was found with a security camera but it does sound similar. Hope this helps.
Hello jdaddaro,
Thank you for your help.
Yes, I talked to the administrator. We tested all variants. Unfortunately without success. The switch can POE, POE +, POE high, and POE Ultra.
And the switch is not loaded with your POE performance.
