BLU100 Falling of IP Network
Hi, I have a BLU100 that periodically falls of an Ip network.
As in the MAC address /IP address will not show up at all.
The only way to get it back on the network is to power cycle it.
I have scheduled nightly reboots and and also purchased a new router but the problem persists.
This particular device is using firmware v6 R4.
I will try R5 and see what happens.
If the problem persists, can anyone think of a Logic solution that will cause the BLU100 to reboot if it can no longer ping the routers IP? is it even possible to issue ping commands within logic?
    This could happen for many reasons and this forum is not the best place to investigate this. I would recommend that you contact BSS technical support or your local distributor in Australia.
  • This could happen for many reasons and this forum is not the best place to investigate this. I would recommend that you contact BSS technical support or your local distributor in Australia.
    I have solved many issues with the help of other BSS users on this forum.
