Home BSS Forum BSS Forum Archive Discussion Soundweb London/Contrio wall controllers and iOS Motion Control
Motion control Parameter presets
Hi!
I'm rather new to Audio Architect and Motion Control.
I have a client that need an iPad to control their venue. A restaurant with many audio zones.
I have want to use Parameter Presets to switch between different scenarios, sources etc. Howerver, i can add a Combo box in the Custom Panel Designer and i can drag'n'drop a Parameter Preset Group to the combo box. It look nice and works fine when i launch the Custom Panel on the PC. But when i load it to the iPad the combo box is empty and it shows \"unattached\" when i open it up. I even tried to make buttons to recall the different scenarios, but it won't work either. Any suggestions how to make this work?
Best regards Joakim.
    Motion Control does not support Parameter Presets. In other words, it cannot send out a Parameter Preset recall message itself, so the Soundweb device must be used to do this.
    To get a button to recall a Parameter Preset:
    In the Logic layer, add a Logic Source wired to a Preset Trigger. Configure the Preset Trigger with the Parameter Presets you require. Then assign the Logic Source button to the Motion Control panel.
    Tip1: The Logic Source can be made \"momentary\" by setting its Auto Off property to 1.
    Tip2: If there are several Logic Sources/Preset Triggers then these can be made to act like \"radio\" buttons. Link all the Logic Sources with a Radio Link.
