Question about contrio buttons
Hi, perhaps this is a silly question, but I'm very new to audio architecht.
I have four parameter presets to control the monitoring system of my studio. I have assign them to the contrio buttons, but I'd like the light to change to the off position if I select a different preset, so I can see very easy what preset is selected.
I tried some logic preset trigger but I can't do it.
What would be the easiest way to do this?
In the Logic layer, add a Logic Source wired to a Preset Trigger. Configure the Preset Trigger with the Parameter Presets you require. Then assign the Logic Source button to the wall controller buttons.
If there are several Logic Sources/Preset Triggers then these can be made to act like \"radio\" buttons (only one button can be on at the same time). Link all the Logic Sources with a Radio Link.
Thanks a lot for the help.
