convert audio to logic
i have some fantasy..
there is some mic in the system, i want that every time the mic is passing some threshold level i will be able to pick this trigger in the \"logic\" area..
can it be done ?? :shock:
When the LED goes On then the Logic Source will go On. The LED goes on when the level reaches 0 on the meter. You can adjust this threshold by changing the Reference.
Mute (or any two-state parameter) -> Logic Source
Source Selector -> Logic Value
Meter -> Logic Comparator
You can also associate Logic with Audio:
Logic End -> Mute (or any other two-state parameter)
Preset Trigger - will recall Parameter Presets
In the Gain Sharing Automixer the \"ON\" indicator will go On when the channel is active. Only one \"ON\" indicator is allowed to be On at the same time. This is usually used for automated camera systems.
In the Gated Automixer, the \"GATE\" indicator will come On when the signal goes past the threshold. The \"OPEN\" indicator will come On when a channel is active. The behaviour of the active channels depends on the NOM and Priority settings.
For more details simply search in the Help document.
Any of the indicators in the Automixers can be associated to a Logic Source.
It works but there is a slight delay, probably because of the preset load time.
We now want to try to do it direct, logic end > mute, it does not allow us.
How can we do it?
The Logic End will then have control of the Mute.
