London Architect Versions and build numbers
In London Architect, the Build Number is found as the first entry in the System Output window.
Go to Edit menu and select System Output.
Firmware version in the Soundweb London device is displayed on front panel LCD and is also displayed in the Network Window listed as \"Application Version\"
The Soundweb London device firmware will have the same number as the London Architect versions.
e.g. London Architect v6.00R5 uses firmware 6.00.05
e.g. London Architect v4.00 uses firmware 4.00.00
If you have any questions please contact your local BSS Audio distributor or technical support.
