What can cause the STAT LED to turn red?
This should mean that the \"design is stopped\" according to the manual.
What can cause this?
I have a BLU-100 running that randomly locks up and the STAT goes green to red.
If yours has already had a file loaded then clearly that's not the issue. Is it by any chance being controlled by a 3rd party control system? If so- that may be the cause of the lock up.
You could try disconnecting the Ethernet cable from the 100 and see if it still locks up after that. My bet would be that it doesn't, and then something on the network is likely the cause.
Of course, if you need a faster answer to any issue, you can contact BSS application engineers directly. Fill out the form on the 'Support' section of the website and someone will get back to you quickly:
http://www.bssaudio.com/en-US/support
Or you can contact your local distributor wherever you are in the world for support. their details are all available on the website too:
http://www.bssaudio.com/en-US/where_to_buy
