Control Outs in Audio Architect
Here is what I got:
I have a button (on/off) in my programming for AA. I placed said button on my iPad. I need this button to trigger an event in a crestron program. I have tested but I guess my brain is too tired. Anybody have a solution or has anyone done this.
Drag the logic button onto your Motion Control iOS panel and you are done.
D
Basically its just a button to turn all the TVs on in a bar.
Hopefully that makes more sense and I appreciate your help. That will help me on the 2nd AV2.
Are both London and Crestron boxes on the same LAN?
Use the Ethernet trigger to control the Crestron device(s)
Are you driving the Crestron from the control logic outs of the London? Stick a logic end in place of the Ethernet trigger in the London's logic design.
Locate and drag the logic end you created in the logic design from the venue explorer on the left onto the applicable control port, using the 'configure control ports' button in the ribbon, shown when you are in soundweb london design mode.
Done.
I had to make some changes in the Crestron. Basically telling it to run the command twice.
I also used a momentary button instead of a discrete on/off.
I was going to post today that I got it but you beat me to it.
