strange SUBSCRIBE behavior
I read the blog post from 2007 with kirchh. It seems to apply to odd behavior that I, too,have noticed. Although it would probably never be a problem with the Crestron interface, I can imagine that someone might create a loop since the command and status messages are identical.
It also probably explains why several of the Crestron 4.2 modules appear to send a subscribe command directly following a set state variable command. I assume that this is because the London will respond to the subscribe request with a status report. Can I depend on this behavior in all cases where I wish to monitor the true status of the London BLU but may wish to change SV's with the Crestron?
I have an installation where a London BLU system may be controlled by either a Crestron or a London Architect custom control panel.
Eric
Eric
Also check the error log for buffer overflows. I had to increase the array size in a few of the SIMPL+ modules which improved reliability.
For help with custom control panels contact your local distributor who are charged with technical support) or contact BSS Audio support.
http://bssaudio.com/en-US/support
