Blu-10 gain limit and gain control resolution
Hello,
I'm using a Blu-10 for system volume control and I'm struggling to get it \"user friendly\".
I need to be able to limit the gain control to 0dB and lower (i.e. no gain). I can manage this on the control panel on the software, but this does not affect the Blu-10.
I also need to be able to set the resolution of the pot to be 0.5dB or 1dB steps.
Are either of these possible?
Any ideas welcome.
Thanks in advance
  • 1) Limiting range. I think the only way to force a subrange limit on a BLU-10 is to use a Gain Mono object. If you are controlling a mixer object or some other gain fader, you can exact-link it to a Gain Mono object, and link the gain mono object to your BLU-10 user control.
    In the Properties of the Gain Mono object you can specify the upper and lower subrange limit.
    2) Resolution. I am not aware of a method to change the resolution or gain value increments on a gain object on a BLU-10.
