Please verify limiter settings.
Hello!
Also posted on PSW.
Rig is
BSS Blu-100 ->
Crown CT2000 (8ohm bridge, 2000 watts), 26db gain set. Attenuated to -6db.
STX815 (8ohms, 800/1600/3200)
I would like to set a peak limiter at the speakers program (1600watts), and an RMS limiter at the continuous ratings (800 watts, the venue has some EDM,dub step playing)
Formula applied is : 10Log(power*imp/0.6)-26db
This would give me, on the soundweb london, a figure of 17.29db for the peak, and 14.28db for the RMS. Using attack times of .2ms and .2s respectively.
For RMS protection, i would probably use a compressor with very high ratio over the limiter.
Is this correct ?
Thank you.
Regards,
Sidhu
Also posted on PSW.
Rig is
BSS Blu-100 ->
Is this correct ?
Thank you.
Regards,
Sidhu
