Soundcarft digital console recall London preset by HiQnet
Soundcarft digital console can produce HiQnet signal to recall the dbxSC32 or 4800 presets using the SystemArchitect.
How to use HiQnet to trigger London preset?
Where's to set the HiQnet number in london?
    A Soundcraft console can recall Venue Presets. It cannot recall Soundweb London Parameter Presets.
    Simply create Venue Presets which contain the Parameter Presets you want to recall (see London Architect Help file).
    These Venue Presets will have an ID number, The ID number is displayed in the Design Window.
    ID numbers are generated in the order in which you create the Venue Presets starting from ID1. So if you want to create Venue Preset with ID 6 you need to create six Venue Presets.
  • ID numbers are generated in the order in which you create the Venue Presets starting from ID1. So if you want to create Venue Preset with ID 6 you need to create six Venue Presets.
