Home BSS Forum BSS Forum Archive Discussion Soundweb London/Contrio wall controllers and iOS Motion Control
HiQnet Motion Control list of supported parameters
Here's a list of currently supported SVs for Motion Control:
AEC
AEC Enable
AGC Enable
Mic Active
NC Enable
NLP Enable
Signal Threshold
AEC Input Card
AEC Enable
AEC Mute
AGC Enable
Dry Mute
Mic Active
NC Enable
NLP Enable
Phantom
Reference
Signal Threshold
Noise Cancelation Level
AGC Max Gain
AGC Min Gain
AGC Max Target
AGC Min Target
AGC Current Gain
AGC Attack
AGC Release
Analogue Input Card
Mute
Phantom
Reference
Gain
Analogue Output Card
Mute
Reference
ANC Gap
Gain
Gap LED
Max
Min
Ambient Threshold
Gap Threshold
ANC Non-Gap
Gain
Max
Min
Ambient Threshold
Automixer Gain-Sharing
Auto
Aux Gain
Aux Mute
Channel Aux Gain
Channel Gain
Channel Group Gain
Channel Mute
Group Mute
Group Route
Off Gain
On
Output Gain Left
Output Gain Right
Output Mute Left
Output Mute Right
Override
Pre/Post
Solo
Polarity
Automixer Gated
Auto
Cascade Link Healthy
Channel Gain
Channel Mute
Default Mic
Gain Left
Gain Right
Gate Open
Hysteresis
Last Mic Hold
Local
Low Priority Duck Gain
NOM Attenuation
Off Gain
On
Output Mute Left
Output Mute Right
Override
Sensitivity
Solo
Threshold
Polarity
BLU Device
All the CobraNet indicators
Most of the BLU link indicators
CM-1 Mute status
BLU link Rx
Reference
BLU link Tx
Reference
Compressor
Auto Release
Gain
Crossover
Gain
Mute
Limiter Threshold
Polarity
CobraNet Input Bundle
Audio Received
Digital Input Card
Bypass
Mute
Reference
Error
Non-audio
Digital Output Card
Bypass SRC
Mute
Reference
Ducker
Range
Threshold
Expander
Threshold
Gain
Bump Down
Bump Up
Gain
Mute
Polarity
Gate
Range
Threshold
Manual Open
Open
Graphic EQ
Band Level
Flat
Hybrid and VoIP Input Card
Channel Mute
Dial Tone
DTMF Detect
Phantom
Phone keys (0,1,2 etc)
Recall
Reference
RX Mute
Store
TX Meter
TX Mute
Gain
TX Gain
RX Gain
DTMF Level
Ring Level
Side Tone Gain
Analog TX Gain
Analog RX Gain
Off Hook
Limiter Active
Current Overload
Input Bundle
Channel Meter
Dropouts reset
Meters Enabled
Leveller
Active LED
Max Gain
Target Output
Threshold
Limiter
Threshold
Polarity
Logic Source
Input
Logic End
Output (only when object has one input)
Matrix Mixer
Crosspoint Gain
Crosspoint select
Meter
Reference
Meter Trigger
Reference
Trigger
Mixer
Aux Mute
Channel Aux Gain
Channel Gain
Channel Group Gain
Channel Mute
Group Mute
Group Route
Output Gain Left
Output Gain Right
Output Mute Left
Output Mute Right
Pre/Post
Solo
Aux Gain
Polarity
N-Input Gain
Channel Gain
Channel Mute
Main Mute
Master Level
Noise Generator
Level
Output Bundle
Channel Meter
Dropouts reset
Meters Active
PEQ
Bypass All
RMS Meter
Reference
Room Combine
