Blu-100, how to set input card gain parameters
Hi,
I'm using a Soundweb Blu-100 and wondering how you go about changing gain increments. As default they seem to be set to 0, 6, 12, 18, 24, 30, 36, 42 and 48 dB
This wouldn't be a problem if you could enter custom gains when running live, however it jump to the nearest default. e.g, enter 20 and it jumps to 18 dB:
Any help would be much appreciated.
Cheers
Olly
Cheers
Olly
If you need fine control between these steps, you have to add a Gain object after the Mic Input.
Brilliant, problem solved. Thanks very much for your help.
Cheers
Olly
