Motion Control
Hello, I have programmed a system using LA and imported controls to SA. I realize I could have done this in AA but there are Blu8v2's on this system and was stuck doing it this way. my issue is I can not get the ipad's to show up online at all. I have added them manually even manually set the HiQnet address to the same and nothing.
They are on the same network and I can ping the ipad from the computer running SA.
Any ideas would be much appreciated.
Regards
Kam
    Close LA and SA. And force quit MotionControl.
    Open SA and then start Motion Control. Motion Control should be detected.
    In Options/Network connectivity it is usually a good idea to set up a single Ethernet interface rather than use \"All Adapters\"
    If you are still having difficulty please contact tech support.
