Parametric EQ N-Input not applying eq on all inputs
Hi,
I recently discovered a problem with a parametric Eq N-Inputs. In this case it is a stereo EQ, where I did some tweaks.
After going offline and storing all the stuff, everything is fine.
When I want to go back online with the BLU160's involved, the software prompt me to receive or push data, which is quite abnormal. If I decide to receive data from BLU160, that Parametric EQ is working only on the first input, and the second is not affected.... The only way to go back in a normal stereo situation, is to double click each frequencies bypass.
I'm using only 69% of processing.
Does anybody have a solution?
