Soundweb Designer on Windows 8
Hello,
I am curious if anybody has had any luck running Soundweb Designer on a PC running Windows 8?? I have some familiarity with Soundwebs, however, I am far from a power user. Any assistance would be highly appreciated.
Thank You in advance.
All The Best,
Chuck \"Chopper\" Boyle
chopper35@gmail.com
All The Best,
chopper35@gmail.com
If you require full functionality with the Event Log, then you need to run Soundweb Designer on a computer running Windows XP or on a Virtual Machine in Wondows 8.
Soundweb Designer is not supported on Windows 8 but it works fine.
Please use the Windows 7 Installer version of Soundweb Designer.
Any luck yet with London Architect on Windows 8?
Thanks.
I have used it a couple of times and from memory I had to enable some kind of 'windows 7 compatibility' function inside of windows.
Can't recall where that was, sorry. My daily machine is Win7 so I can't look.
Personally I've not had to use any compatibility modes.
