London Arch not reflecting real time state of logic objects
So here it is;
1 x Blu 100 being used for both normal audio processing (as a digital mixer), and a control system (turning on/off an LCD TV and selecting a source to display on that LCD).
I have my laptop connected to that network (used for making changes and for monitoring the status of logic states, serial trigger table and ethernet trigger table used to send out commands to the LCD).
I have also used system architect to configure an ipad running motion control to control the operation of the LCD. I have also created a page with the 16 channel faders to allow control over the \"mixer\" part of the design.
I've checked all the strings I'm sending out and all are correct and the system works and switches as it should - no problem at all.
My problem is with london architect when I go online. In this mode architect does not reflect the selections/changes made in motion control. If I adjust a fader in the mixer part, and the fader within london does not follow - however, if I adjust te fader in london, the fader in motion control works.
The same applies for the logic. If I press a button (in motion control) assigned to a logic source (within London), the logic state does not change within London - however, if I select that button within London, motion control reflects that.
I have reset my laptop, cycled power to all devices and ran london architect while System architect has been shut down - all with the same result.
The only thing I have not done is tried another laptop.
If anyone can suggest something else I may have overlooked it would be greatly appreciated
