3 Wire Mode
I have a design where I'm using a momentary physical button in a room to trigger power for a system. I also have a virtual button in the GUI design running on the user's computer. The physical button is connected to the logic input ports and a relay connected to the logic output ports to actually control the power strip.
I want to add a 10k pot in the room to give them a single volume control. I would need to change the control ports to 3 wire mode. To keep the physical button working, I would have to tie the wire from the switch to the control input to the \"R\" terminal with a 4K7 resistor right?
The relay is a DPDT. I tied the second half of the relay back to a logic input so the logic knows which state the system is in. That would also have to be tied to \"R\" as well right?
Attached is a picture showing the hookup of the BLU, relay, power strip, and wallplate with button and LED
https://www.dropbox.com/s/ya5egcpedblzq8k/BLU%20Power%20Relay.JPG
