Horizontal Meters
I have figured out how to make a meter horizontal, painless. Yay.
Is there a way to change the direction of the indicator travel ?
So typically the signal indicator moves from left to right, I would like to make it move from right to left.
Mirror does not seem to be quite what I want.
Any ideas ?
Thanks in Advance
A
Any ideas ?
Thanks in Advance
A
Select it and on the top menu go to Gallery>Add>Selected objects.
Give it a name like Horizontal Meter-Left and save it.
Then copy out the meters you want to look like it to your control page and in the Gallery panel on the left find your newly added object (it's under User>Controls). Drag it and drop it on your vertical meters to make them horizontal left.
It works well for me here.
Okay That is a crazy cool solution !!!
Thank You !
