On/Off Switch
Hi all,
Im looking to add an On/Off Switch to one of my zones in my program.
When the switch is in the ON position i want a green led to trigger and when in the OFF position i want the red led to trigger.
Also when in the OFF position i want to mute 2 microphones and 1 output and then in the ON position to unmute the 2 microphones and 1 output.
Is this possible?
Any help would be greatly appreciated.
Is this possible?
This is quite easy.
There are several ways to achieve this. Here's one:
Create a Parameter Preset Group containing 2 presets (ON & OFF)
Assign the mute buttons of the in- and outputs you want, to this PPG.
Now, have a look at the attached pic.
Create a similar logic circuit.
Assign the Logic Source to a control input (Only if you're using an external switch, obviously)
The Preset Trigger must contain the 2 presets you just made earlier (ON & OFF)
Assign the 1st Logic End to control output 1 (Green LED)
Assign the 2nd Logic End to control output 2 (Red LED)
That's it.
