cobranet bundels
hello
we want to add to our bss family a blu 320 and a blu 160. Our mission is to capture audio from our Bss system to 4 different Pc's in order to use it for different tasks with different applications.
For this we will add 4 pci-e audio cards with cobranet ASI5308 (http://www.audioscience.com/internet/products/sound_cards/asi53xx_6316.htm)
The idea is to recieve on the 4 computers simultaniously 4 different bundels of 8 channels each (each card recive one bundle with 8 channels) from the blu-320.
One of the cards will also transmit one bundle to the 320 (this audio is going to bss system from one application that playback some audio files).
in total - 3 cards recive 3 bundels of 8 channels from the 320 and one card recive one bundle and transmit one bundel simultaniously to the 320.
5 diffrent bundels in total. all bundels in unicast mode thru switch.
Will it work for us?
Another question is about cards configurations in the blu-160. Do we need to order it full with 4 cards, or we can order it only with one card and to add the other 3 later by ourself. Cause right now we need only one hybrid card to do some tests. If it will work we will add another 3 hybrid cards later.
Hope it is not too long, sorry
Thank's alot
Thank's alot
Firstly, you can order the BLU-160 with just a single card no problem, then add other cards later.
Your CobraNet scheme sounds fine to me- though you will need to ensure you match the card settings with the BLU-320 settings in relation to CobraNet latency, sample rate and bit depth.
Once that's done all should work fine.
D.
its interesting if some one has try work with this cards with the bss... ?
