Control Panels
One day I opened my project to edit some control panels. In the \"new\" mode I found an analog meter and several cool faders and meters...I went on editing, cutting some stuff from the defaults and adding them to my custom panel....Then I wen to get some items from the library ....everything I inserted came in with an ! and a bounding box.... seems like I lost a link, any idea?
You can still find the controls you want on your custom panel in the Design Tree. Just navigate to the Blu processor/Default Configuration and find the processing bloc. Then drop elements from there onto your now orphaned controls.
Within a RADIO link, at all times, exactly 1 parameter within the link group will be HIGH, and all other parameters are LOW.
By \"INVERT\" link, I'm assuming you simply mean the opposite of a RADIO link. If my assumption is correct, then...
within an INVERT link, at all times, exactly 1 parameter within the link group will be LOW, and all other parameters are HIGH.
You're correct: currently no such link-type exists. But you can create one using Logic.
Example:
You have 4 mutes. You want to \"INVERT link\" those 4 mutes. In other words, you want exactly 1 mute (no more, no less) to be unmuted at any point in time (with mutes, \"muted\"=HIGH, and \"unmuted\"=LOW).
First, create the following logic circuit:
[Logic Source] --> [NOT] --> [Logic End]
Then copy/paste that logic circuit 3 times, so you have 4 circuits in total.
Then RADIO LINK the 4 [Logic Source] objects together.
Then link 1 of the 4 mutes to a [Logic End]. Repeat 3 more times until all 4 mutes are linked to a [Logic End].
Then point your control system (LA control panel, 3rd party controller, BLU-10, BLU-8, iPad, GPI, etc....) at the buttons within the [Logic Source] control panels.
Done.
Watch the mutes as you use those buttons. Only 1 mute will be unmuted at any point in time.
WARNING: do not use this on Room Combine mutes. It will create a control loop.
Can third party Crestron device access the control panels, giving them one interface/module or do they need to access the actual object?
Also Full screen is stuck on and shift F5 doesn't bail out!?!
