We have a BLU-160 in a Football Stadium. The neighbors complain when the announcer yells into the mic. Can I use the Compressor or Limiter to keep the level below a preset level?
Seeing how you are most likely not an audio person/DSP programmer, the long answer is yes, but find someone who knows how to add it to the signal flow, deploy the new configuration and finally configure the parameters so that the compressor works as intended.
