configuration
i have 20 analog mics and require to purchase 5 analog card for blu-160 chassis..do i have to make a configuration signal path? if yes do you have some type of matrix sofware i have to use?
    A BLU-160 chassis will accept four analog input cards only which provides a total of 16 input channels. You will need to use a BLU-BIB or BLU160/120 to provide the outstanding 4 inputs you require.
    The signal path in a Soundweb London device is not fixed and will need to be configured using a PC application called HiQnet London Architect. The devices and PC communicate using Ethernet.
    You can download this application and explore the wide choice of training options from the BSS Audio website.
