scale in grafic fader
hello
im am sorry for my english
i am working on bss project with two 160 and two 100
i am tring to add scale with numbers to a grafig fader in costum panel
the fader cap is from the gallery and without the fader background
i try to put a 1-10 numbers in the scale and it gives only a 1 in te botton and the 10 up' but without the all rest numbers in all the scale.
need some help
thenks
  • Select the fader then in the Properties of the fader under Scale you can add and remove Tick Positions. \"Click Button to Edit\" then manually add as many as you need.
    Also, you can turn on and off the scale and show it on either side of the fader or both sides.
