HiQ net iOS control
It's great that there is a native iPhone and iPad control app. I can't wait to try it.
But can any of the Harman people explain what exactly is not possible in the app?
Reading the only review on iTunes it seems that the app is fairly limited:
Get used to reading the words \"HiQnet Motion Control does not support this type of control\" when working in System Architect. I didn't expect to find it would support the intricate designs I usually create in London Architect but it can't even support half of the basic controls in System Architect.
It's functional, I won't take that away from it. That said, functional is not nearly enough to keep my customers happy.
  • Here's a list of currently supported SVs - I organized them alphabetically by Processing Object and then by Parameter:
    AEC
    AEC Enable
    AGC Enable
    Mic Active
    NC Enable
    NLP Enable
    Signal Threshold
    AEC Input Card
    AEC Enable
    AEC Mute
    AGC Enable
    Dry Mute
    Mic Active
    NC Enable
    NLP Enable
    Phantom
    Reference
    Signal Threshold
    Analogue Input Card
    Mute
    Phantom
    Reference
    Analogue Output Card
    Mute
    Reference
    ANC Gap
    Gain
    Gap LED
    Max
    Min
    ANC Non-Gap
    Gain
    Max
    Min
    Automixer Gain-Sharing
    Auto
    Aux Gain
    Aux Mute
    Channel Aux Gain
    Channel Gain
    Channel Group Gain
    Channel Mute
    Group Mute
    Group Route
    Off Gain
    On
    Output Gain Left
    Output Gain Right
    Output Mute Left
    Output Mute Right
    Override
    Pre/Post
    Solo
    Automixer Gated
    Auto
    Cascade Link Healthy
    Channel Gain
    Channel Mute
    Default Mic
    Gain Left
    Gain Right
    Gate Open
    Hysteresis
    Last Mic Hold
    Local
    Low Priority Duck Gain
    NOM Attenuation
    Off Gain
    On
    Output Mute Left
    Output Mute Right
    Override
    Sensitivity
    Solo
    Threshold
    BLU Device
    All the CobraNet indicators
    Most of the BLU link indicators
    CM-1 Mute status
    BLU link Rx
    Reference
    BLU link Tx
    Reference
    Compressor
    Auto Release
    Gain
    Crossover
    Gain
    Mute
    Digital Input Card
    Bypass
    Mute
    Reference
    Digital Output Card
    Bypass SRC
    Mute
    Reference
    Ducker
    Range
    Gain
    Bump Down
    Bump Up
    Gain
    Mute
    Gate
    Range
    Graphic EQ
    Band Level
    Flat
    Hybrid Input Card
    Channel Mute
    Dial Tone
    DTMF Detect
    Phantom
    Phone keys (0,1,2 etc)
    Recall
    Reference
    RX Mute
    Store
    TX Meter
    TX Mute
    Input Bundle
    Channel Meter
    Dropouts reset
    Meters Enabled
    Leveller
    Active LED
    Max Gain
    Target Output
    Limiter
    Threshold
    Matrix Mixer
    Crosspoint Gain
    Crosspoint select
    Meter
    Reference
    Meter Trigger
    Reference
    Mixer
    Aux Mute
    Channel Aux Gain
    Channel Gain
    Channel Group Gain
    Channel Mute
    Group Mute
    Group Route
    Output Gain Left
    Output Gain Right
    Output Mute Left
    Output Mute Right
    Pre/Post
    Solo
    Aux Gain
    N-Input Gain
    Channel Gain
    Channel Mute
    Main Mute
    Master Level
    Output Bundle
    Channel Meter
    Dropouts reset
    Meters Active
    PEQ
    Bypass All
    RMS Meter
    Reference
    Room Combine
    BGM Gain
    BGM Mute
    BGM Source
    In Active Group
    Master Gain
    Master Mute
    Source Gain
    Source Mute
    Source Matrix
    Input
    Source Selector
    Input
    Timed Gain
    Cancel Fade
    Fade
    Gain
    Mute
    Timer Gain
  • Thanks Iain,
    That is indeed a fairly limited set of controls.
    On my control panels I rely on Logic Sources, Gains and source selectors a lot. Sometimes I give the users some basic EQ and controls for live microphone input.
    With the currently available set I could not set the mic input sensitivity, turn on high pass filter (without some routing gymnastics) and adjust mic dynamics processing.
    I hope this is all still work in progress and you will be adding more controls to the list.
  • We'll be adding more controls and support for additional parameters in future versions of HiQnet Motion Control and HiQnet System Architect.
    In the meantime, there are some workarounds for getting into the Logic domain such as using e.g. Mute buttons from N-Input Gains to drive the Logic Sources, and placing the Mutes on the iOS panels. There are creative workarounds for other parameters too. 8)
    I'll be keeping my eyes on the Soundweb London User Group to monitor the iOS-related posts - it'll help us make sure we're prioritizing the new controls and parameters correctly.
  • Cheers for this Info, Really need those logic sources
  • I created a set of parameter presets for the positions on an input gain fader. There would be 9 total. I then used a 16 input source selector and tied that to a logic value block that had four outputs. The logic value block was tied to a preset table block. The end result is a source selector that each source recalls the preset for the corresponding step on the gain fader. 1=0db, 2=6db, 3=12db etc.
    After all that, I set the inputs on the source selector back to 9. I exported that and imported to System Architect as a drop down box. It seemed to work
    A little tedious, but it's not too bad if you have only a couple gains to work with. Unfortunatly, since much of the other rotary type SVs (ration on a compressor for instance) aren't in the list, I haven't found a way to make those work yet.
  • When Can we expect an update with More comprehensive LA controlls supported?
    Or has this been put on the Backburner due to the upcoming Audio Architect release? From all the info on the Harmon website is appears obvious that Audio Archetect might see the end of LA?
  • We're about to provide support for a significant number of additional SVs in HiQnet Motion Control but they have to go through final testing before I can publish the list.
    I promise I'll post the list here as soon as I can.
    :shock: Watch this space... :D
    Thanks for the update Ian
  • As promised, here are the newly supported SVs:
    Gain
    Polarity
    Timed Gain
    Polarity
    Mixer
    Polarity
    Automixer
    Polarity
    Gated Automixer
    Polarity
    Gate
    Threshold
    Manual Open
    Open
    Limiter
    Polarity
    Ducker
    Threshold
    Leveler
    Threshold
    Expander
    Threshold
    ANC
    Ambient Threshold
    Gap Threshold
    Non-Gap ANC
    Ambient Threshold
    Crossover
    Limiter Threshold
    Polarity
    Noise Generator
    Level
    Tone Generator
    Level
    Meter Trigger
    Trigger
    Room Combine
    Partition
    Analog Input Card
    Gain
    Digital Input Card
    Error
    Non-audio
    AEC Input Card
    Noise Cancelation Level
    AGC Max Gain
    AGC Min Gain
    AGC Max Target
    AGC Min Target
    AGC Current Gain
    AGC Attack
    AGC Release
    Hybrid Input Card
    Gain
    TX Gain
    RX Gain
    DTMF Level
    Ring Level
    Side Tone Gain
    Analog TX Gain
    Analog RX Gain
    Off Hook
    Limiter Active
    Current Overload
    CobraNet Input Bundle
    Audio Received
    Logic Source
    Input
    Logic End
    Output (only when object has one input)
  • I have a question... I am trying to create an IOS panel for control of a venue. The system is composed of a Blu-100 and a Blu-bob. I dont see any way of exporting the BOB to a device file. Is this not currently supported? Will it be supported and if so, any idea when?
    The BLU-BOB is not software controllable. There are no parameters which can be changed inside the BLU-BOB.
  • Thanks, I realized that after I had posted, I dont know what I was thinking... oops... :(
  • So when will I be able to get control of our AVB devices via the IOS app?
