More than 6 fader/enable buttons to control inputs
Is it possible to wire more than 6 faders and respective enable buttons to control inputs?
For each control, I have a fader wired to a control port, a latching button that is wired to a control port that \"enables\" fader control in the following way - linked to the button is the fader's mute state, and in logic I switch to unmute another gain object when the button is pressed. the other gain object is linked to a timed gain, controlled via serial. In this way, I can either use serial control or push the button and ride the manual fader.
My question is, am I limited to 6 of these (due to 12 control inputs) or is there a way around that with just one London device?
