How to set the parameter preset in BLU 100?i able to set calendar to trigger the preset but unable to set preset.....in this case, I use calendar to trigger the volume.......Than you
I can think of four places that describe how to create Parameter Presets:
1. London Architect Help file
2. Interactive Training Modules: \"Parameter Presets\"
3. Application Guide: \"Using Parameter Presets\"
4. London Architect Online Video Tutorial: \"Parameter Presets\"
You can't save presets while in operating mode. Presets are compiled along with the rest of the design and deployed to the DSP.
It's very unfortunate, but that's how the system works.
There is one object that tries to help the situation a bit. Gain Timed has 4 buttons that will recall a gain setting, and that gain value is available to you while on line.
So if you do 4 presets that just trigger those volume fades, but don't contain actual gain settings, you can tweak the actual volumes of presets while the system is running. The limitation is that you only get 4 volume settings. If you have more than 4 volume presets to store, you would have to get creative with stacking these gain blocks and saving initial presets accordingly.
