matrix mixer control
Is there a way to link a fader on a custom control panel to a crosspoint on a matrix mixer? Or a button that would turn the same crosspoint on and off? It seems like the whole matrix is a single object.
I have a feeling this may be a \"use serial strings with pin 2 and 3 shorted on the RS-232 port\" kind of answer.
  • Go to the design tree, find the crosspoint on/off (or volume) that you want, and drag it to a custom control panel. If you just drag and drop it, you'll get a default control. If you want a specific style of control, create the control first and then drop the SV from the design tree onto it.
    That's the same happy-dance you have to do if you want to link individual controls in a matrix or if you want to include just part of a matrix in a parameter preset.
    Dan
  • Im trying to do something similar if not the same -
    Ive tried this , but it only seems to move the whole object doesnt seem a way of moving each rotary dial?
    am i being stupid?
    or have i miss understood what you have written
    Dan
  • To move the rotary dial, you have hold down the shift key. So go into operate mode and hold the shift key, or hold down Alt+Shift while in design mode.
    To drag an individual dial from the matrix onto a custom fader or object, go to the design tree/devices/BLU-160 (or whatever processor)/Processor name/default config/Matrix Mixer/Mixer Name/output folder...and there it is.
    Those icons in the tree can be dropped from the tree onto a custom panel
