Using N-Input Gains with Crestron Control
Does anyone know how (and if you can even) control the Master gain on an n-input gain using the crestron control module? I am using 4.2 and I can only control the gain of channels 1 and 2, but not the master gain, as it does not have an input #.
Yep... or you could do it the easy way which is using the 8-chan basic module. Just a thought.
Dan
Use the Chan_Offset$ input: for channels 1 to 8 use 0, for channels 9-16 use 1, etc..
