waiting for writing design file to devices
Should this take 30 minutes each time I exit the online mode?
My system contains 1 BLU-10, 5 BLUE 160s, and 9 BLUE 120s.
Dan
If you're experiencing long wait times while writing the design file, there's possibly something wrong with one of your devices which is slowing down the transfer. There's a good chance you could eliminate it if you reset all of the devices and then reload the design file. To completely reset a device:
click on the Windows START button click on RUN type in
cmd and hit entertype in telnet xx.xx.xx.xx (xx.xx.xx.xx is the IP address of your device)
username is bssaudio
password is monkey
type in purgexml (all one word) and wait for it to finish
type in formatflash (all one word) and wait for it to finish
type in reboot
close the command window
repeat for each device
[/list:u]
DO NOT DO THIS UNLESS YOU KNOW HOW TO SET UP A SOUNDWEB LONDON DEVICE FROM SCRATCH. After doing this, the device will be completely reset. That includes IP address, name, etc. If you don't know how to setup a device from scratch, including how to setup your computer's IP address and subnet so that you can talk to a new device, then you're going to have a nightmare on your hands.
Alternately, you could turn off the silly \"Save to Device Network\" option and just do it manually when you actually need to save a modified version of the design file. To turn autosave off:
click on the TOOLS menu select APPLICATION PREFERENCES click the FILE tab in the Save to Device Network section change the dropdown selection to NO.[/list:u] That will stop LA from wasting time saving the design file to the device network every time you go online. When you actually make a change to the design file, just save it manually by clicking on the FILE menu and selecting SAVE TO DEVICE NETWORK. It'll still take a long time to do because of the underlying problem in your system, but at least London Architect won't be plugging away like a savant trying to save every time you go online. Dan
Poor word choice on my part. I have groups of linked mute buttons. Currently one specific BLU160 powers up with two members of a specific linked group always muted regardless of whether the linked group is muted or unmuted via the BLU10. When I connect a computer and go online, the two mute buttons start working with the rest of the group as intended. They will then behave correctly until the BLU160 is power cycled.
I created the LA file, so I will try your reset instructions to see if that clears the condition.
Thank you for your suggestions.
