PC control over multiple 334's
So I am trying to control multiple 334's via my PC, what is the easiest way to do this? Additionally I would like to run signal from FOH down my snake. I have some XTA's where I use a USB to 485 where I converted the RS485 into an XLR and am able to loop through the XTA's using XLR's so im not unfamiliar with this type of content however the whole combo of RS232 and midi thru's, in's, and out's confuses me. Any help would be greatly appreciated.
LA can handle up to 64 serial ports. All you have to do is click on the TOOLS menu, then APPLICATION PREFERENCES, then select the SERIAL tab to enable the ports you want to use.
Dan
moxa.com
The least expensive way that I know of to control 12 Minidrives with London Architect will be a Moxa NPort 5610-16 which gives you 16 serial ports for $945. You can get ethernet from FOH to wherever the Minidrives live using cable, wifi, whatever.
Dan
