Using the DI Message Tool to create serial strings
When deploying a Soundweb London system, it may be required to control it from a 3rd party control system. This may be a complex programmable control system or a simple wall controller sending pre defined strings.
In the later case we can use the Direct Inject Message Tool to help generate the serial strings that are needed to control the Soundweb London device.
More.....
>>>Click here to download the full PDF.<<<
__________________
Technical Support Team
BSS Audio
8760 South Sandy Parkway
Sandy, UT 84070
