Convert Blu-80 to Blu-800
Not sure if this is possible...Here is my situation.
I have a Blu-80 in my system that needs repair, fan is going. It is controlled via Crestron.
I have read in an earlier post that \"Hot Swapping\" devices would resolve the issue (blu80-blu80). My only issue is that I only have a Blu-800 that could be used in the meantime until the repair is made.
Could I convert the Blu-80 into a Blu-800 in the design without losing the Crestron control?
P.S. Dan, You rock! Thank you for all of your posts from the past and in the future!
  • Open the design file, click on the TOOLS menu, and select LONDON DEVICE CONVERSION. Select BLU-800 in the dialog box, then save the design file, close the design file, and reopen the design file. You'll get a dialog box asking if you want to convert the device. Let it do the conversion and then save the file again.
    Dan
