HiQnet London Architect v3.04 Now Available For Download
HiQnet London Architect v3.04 is now available for download
Changes in v3.04:
Full-Bandwidth Acoustic Echo Cancellation (AEC) Algorithm - Full-bandwidth AEC algorithm added (see below for additional notes)
This version also contains minor bug fixes. Go to Help -> Read Me… within HiQnet London Architect v3.04 for further details.
Download HiQnet London Architect v3.04 now from http://www.bssaudio.com/software.php
Additional notes:
The existing 8kHz-bandwidth AEC algorithm is optimized for POTS, VoIP phone system and digital phone system applications. The new full-bandwidth AEC algorithm facilitates enhanced fidelity for specific applications, while also offering a reduced processing latency. A property within HiQnet London Architect v3.04 allows users to switch between the new full-bandwidth AEC algorithm and the existing 8kHz-bandwidth algorithm. Dedicated full-bandwidth ‘dry’ signals for local sound reinforcement or recording are offered for both AEC algorithms.
Existing installations can be upgraded to accommodate full-bandwidth content, without the requirement for additional hardware. However, when upgrading systems to HiQnet London Architect v3.04, they will continue to use the 8kHz-bandwidth AEC algorithm unless manually switched to use the new full-bandwidth AEC algorithm. Therefore, changes will not be forced upon existing systems.
New Soundweb London designs will default to using the new full-bandwidth AEC algorithm, which also gives excellent performance with POTS and VoIP systems, in addition to the accommodation of full-bandwidth content.
Changes in v3.04:
Additional notes:
