Best 8 channel mixer preset
    The positions of the controls in a Mixer can be stored and recalled in a \"Parameter Preset\" or a \"Preset\". What is \"best\" for you depends entirely on your application. If you need to quickly recall stored Mixer settings then the most likely option is to use \"Parameter Presets\".
    Creating Parameter Presets is clearly defined in the Soundweb Designer Help file. Simply search the Index for \"Parameter Presets\"
