FDS-334 serial control with Architect
I have problems to have Architect find the FDS-334T even the comm. is right set and the FDS-334T is upgraded to last firmware. I use comm. port 1 from dropdown, restarted Architect, but it will not be visible in Network window. Any hints..?
Tip: check that Midi-mode in the Minidrive is set to PC.
/Chris
