9088 + 9088 expander -
trying to cut down on the amount of cable im humping around, im thinking bout running 8 lines of audio over CAT5 using the 9088 + 9088 expander-
I realise its not actually CAT5 protocol, but does use CAT5E cable-
couple of questions:
1) I assume the 9088 8in 8out lives at the desk end, put audio through it outputting on network- CAT5 to the expander- and output from that into the amplifiers? im using the 9088 as a processor to run 8 way monitor mix or equivilant
2) is there any obviously problems with latency? with what i propose to do?
3) The cat5E cable- is it pin to pin or a crossover cable? I propose to run it for 50 meters.
4) Im assuming that all the processing is done on the master unit and the expander mearly facilitates the cat5 - audio conversion?
thanks in advance
Dan
