Home BSS Forum BSS Forum Archive Discussion London Architect Application Guides
9015/BLU-6 controling 8 different volumes
Many people have asked for a way to control eight different inputs or outputs with a 9015/BLU-6. Here's how:
Step 1) First, we need something to control. Place an 8-channel n-input gain in the design file and run the 8 signals through it that we want to control.
Step 2) We need a way to have the rotary selector make changes to logic. Since a Logic Value can't be assigned directly to a control input, we'll need to do this the hard way. Place a source selector in the design file and assign it to a control input, then link it to a logic value object.
Step 3) We need a way for the up/down buttons on the 9015 (American name for the BLU-6) to control logic. Place two logic sources in the design file and link them to control inputs.
Step 4) Run the logic value and the logic sources through a bunch of ANDs (or a truth table) so that we end up with 16 data lines. One of these lines being on for each possible combination of a pressed button and a source selector position. So we have 1 up, 1 down, 2 up, 2 down, etc.
Step 5) Take these 16 logic lines and wire them to the 16 inputs of a serial trigger/table set for list mode.
Step 6) Program the first pair of serial trigger/table inputs to send DI_BUMPSVPERCENT commands to:
HiQnet Node Address 0x00 0x00
Virtual Device 0x03
Object ID 0x00 0x01 0x00
SV ID 0x00 0x00
The first input needs to be programmed to send an up bump and the second to send a down bump. You can set them for whatever % bump you want.
The remaining 7 pairs of inputs are exactly the same but the SV IDs are:
2 - 0x00 0x01
3 - 0x00 0x02
4 - 0x00 0x03
5 - 0x00 0x04
6 - 0x00 0x05
7 - 0x00 0x06
8 - 0x00 0x07
Step 7) THE MAGIC! - Stick a DB9 connector into the serial port on the back of the Soundweb London device after soldering pins 2 and 3 together on the connector.
Now, when you push the up/down buttons on the 9015, the Soundweb London device will send serial commands to itself and bump the channels of the n-input gain object up/down.
Here's a demo file that does exactly what I just described.
http://www.bsstechsupport.com/public/forumfiles/9015BLU6Logic.zip
Dan
