Connecting a SW9012US to a Blu-16
I'm looking for a guide to explain how to switch between EQ preset settings in a Blu-16 with a SW9012US. I also need a volume control for one output.
    Assign the Presets to the 9012 5-way switch: Drag the Parameter Preset Group from the Design View onto your chosen Control Input, also in the Design View. Choose the \"Analogue Input\" option when prompted.
    Assign the Level to the 9012 rotary pot: Drag the Fader from your processing object onto your chosen Control Input. Choose the \"Analogue Input\" option when prompted.
    Note: You MUST have a Parameter Preset Group containing exactly 5 Parameter Presets. If you have less than that, you must create \"empty\" Parameter Presets to make a total of 5.
