HiQnet London Architect v2.02 R3 Now Available for Download
HiQnet London Architect v2.02 R3 is now available for download
New Features in HiQnet London Architect v2.02 R3: -
Logic End Enhancement – Ability to run a command added to Logic End
This release also contains minor bug fixes.
Download HiQnet London Architect v2.02 R3 now from http://www.bssaudio.com/software.php
*compatible with HiQnet System Architect version 1.8*
**Version 2 History**
New Features in HiQnet London Architect v2.02 R2: -
Convert to Fixed / Convert to Dynamic (Matrix Mixer / Matrix Router) – Processing Object optimization facilitating increase in HiQnet London Architect design file efficiency
New Features in HiQnet London Architect v2.02: -
Parameter Export – Export parameters from HiQnet London Architect for control of Soundweb London devices from HiQnet System Architect* Custom Control Panels
Wiring Enhancements – Wire single or multiple wires back to existing wires
(also includes v2.00 R4 maintenance fix)
*requires HiQnet System Architect 1.70.1.0 or later
HiQnet London Architect v2.00 R4 Notes.
HiQnet London Architect v2.00 R4 is an important maintenance release and addresses an issue in HiQnet London Architect v2.00 R2 where systems including BLU-800, BLU-320, BLU-160 or BLU-120 devices may set up input / output cards incorrectly on boot. Incorrectly set up input / output cards can result in failure to pass audio through those cards.
It is important to note that BLU-80, BLU-32 and BLU-16 devices do not exhibit this issue.
Whilst this issue is extremely intermittent, BSS Audio recommends that users upgrade systems including BLU-800, BLU-320, BLU-160 or BLU-120 devices at the earliest opportunity.
New Features in HiQnet London Architect v2.00: -
New Family Members Support – Support for BLU-800, BLU-320, BLU-160 and BLU-120 devices
BLU link Support – Support for low latency, fault tolerant digital audio bus of 256 channels
Room Combine Processing Object – Comprehensively featured Processing Object dedicated to room combining applications
Dynamic Meters – Monitor signal presence in multiple places while online without pre-placed Meter Processing Objects
BLU-8 Lockout – PIN based lockout feature for the BLU-8 adding security for controllers placed in public areas
Internal Ambient Temperature – Monitor the internal ambient temperature of BLU-800, BLU-320, BLU-160 and BLU-120 devices
BLU-10 Contrast Control – Adjust BLU-10 contrast for different viewing angles
Audio Coupler Processing Object – Simple Processing Object to allow custom renaming of signal names and provide a joining object for replicated sections of audio processing
Right-Click Properties – Right-click access to Properties
Copy / Paste Online – Copy and Paste Control Values when in Operate Mode and Online
Sub-Ranged Gain – Addition of Sub-range to Gain Processing Object allowing sub-ranged Control Port control of parameters
Default Control Panel Channel Labels – Addition of channel labels to Automixer, Mixer, N-Input Gain and I/O Card Default Control Panels
Truth Table CSV Import – Populate Logic Truth Tables by importing CSV files
Instant Messaging – Instant Message amongst multiple control PCs
Device Conversion – Convert BLU-xx devices to BLU-xx0 devices
