Custom Meters?
Does anyone have any ideas on how to make (from scratch) custom meters?
I'd love to have some rounded meters (and a few other things).
So, if you've got any ideas, I'm open to hear them.
Be good or have fun!
Decide how many different colours (stages) you want.
Make an illuminated and dark version of each colour.
Import those images to the Gallery in LA.
Create a Graphic Meter object on a Custom Control Panel.
Assign the Gallery images you created to the Graphic Meter object.
When you're done, select the object and Save Selection to Gallery.
You'll now find that meter object in your Gallery | Collections folder for ever more.....
Mart
Thanks for the heads up!
Be good or have fun
Unless there's something I'm missing here. Like perhaps using one meter to indicate the lower register and another for the upper?
Thanks for the input,
Dan
...or can you guys figure it out now that you know it's definitely possible?
Dan
I used the second image as the \"Rotary Image\". The left side of the image is transparent white. When the rotary spins to reflect the meter state, it covers and uncovers the underneath static image to show the curved meter.
First Image--->
I set the background color to match those two images. Here's what it looks like with the various colors changed so that you can see all of the parts.
Dan
