Line level shifter for 9088 original (non ii)
Can I have some help on this one please?
Will I need to place a line level shifter between my HTPC with its 8 unbalanced audio outputs - and my 9088 with its 8 balanced inputs?
So, the answer is NO. You wire from the ground of your unbalanced to the soundweb ground. You wire from the positive of your unbalanced to the soundweb positive. You place a jumper wire between the soundweb ground and the soundweb negative.
Dan
That's good news (saves me money).
I was referring to a unit such as the Aphex 228 or Ebtech LL S8.
Andrew
Not optional. Not just for fun. Play around with it and you'll hear why.
Dan
Dan
I hear you and I'll heed the warning
Andrew
