Yet another multiple pc question.
I understand that with 2 pcs the actual design must be the same on each pc ( seems like a best practice is to load dfrom the network and sync from devices )
It turns out that due to space limitations I will have different size monitors with different aspect ratios on an upcoming job. I assume ( boy is that dangerous ) that if I have different control panels on each pc ( so that the displays are both full screen ) I won't have a problem...right?
  • Hi Hanalee,
    I have a design with 2 PC's. The control computer is 1280x1024, the remote computer is 800x600.
    I have set up 2 logins, so the control computer sees its 'own' controls and correctly sized pages.
    The remote computer then has a different set of pages that it references at the correct size.
    If you enable security, you can specify the login start page of the security profile (you can have a different one for each profile)
    Has been working really well for the last year or so.
    Cheers
    Rob
